Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
Carefully insert the new SSD into the adapter, using the length of old drive as a reference for when the SSD is fully in the adapter.  The lengths should be the same. Insert the SSD and the adapter into the Socket, pushing inward in a straight fashion.
  • Carefully insert the new SSD into the adapter, using the length of old drive as a reference for when the SSD is fully in the adapter. The lengths should be the same.
  • Insert the SSD and the adapter into the Socket, pushing inward in a straight fashion.
  • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  • NVMe Drives can cause kernel panics due to sleep /hibernation issues. This can be turned off with the following command.
  • From a Terminal, use the following command to disable hibernation: ----"sudo pmset -a hibernatemode 0" ---- If you later want to enable hibernation, use: "sudo pmset -a hibernatemode 3"
Insertar traducción aquí
