Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 22 guías que incluyen este paso.
Inglés
Holandés
Paso 4
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display. Rotate your spudger toward the rear bezel to separate it from the front bezel. If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
  • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
  • Rotate your spudger toward the rear bezel to separate it from the front bezel.
  • If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
Insertar traducción aquí
