Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Español
Paso 3
As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly. Place a suction cup near the bottom edge of the display.
  • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
  • Place a suction cup near the bottom edge of the display.
  • Pull on the suction cup with strong steady force.
  • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
  • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
Insertar traducción aquí
