Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Español
Paso 2
There is a high risk of damaging the display panel if this opening procedure is improperly followed. The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure. There are two different seams between the body and the screen of the phone:
  • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
  • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
  • There are two different seams between the body and the screen of the phone:
  • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
  • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
  • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Insertar traducción aquí
