Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable. Run the spudger along the full length of the tape to disconnect it from the rear case. Run the spudger along the full length of the tape to disconnect it from the rear case.
  • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
  • Run the spudger along the full length of the tape to disconnect it from the rear case.
Insertar traducción aquí
