Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 4
Be very careful when performing this procedure! If you put too much pressure on the display, you risk cracking it. Wedge a plastic opening tool between the plastic front panel and display. Be very careful that you wedge it in the same location shown in the first picture.
  • Be very careful when performing this procedure! If you put too much pressure on the display, you risk cracking it.
  • Wedge a plastic opening tool between the plastic front panel and display. Be very careful that you wedge it in the same location shown in the first picture.
  • Slide the plastic opening tool across the length of the display. This should loosen the glue binding the display to the plastic front panel.
  • Rotate the display 180 degrees and free the bottom side of the display in the same manner.
Insertar traducción aquí
