Saltar al contenido principal
Inglés
Español
Paso 7
Verify Palm Rest Connectors are clean, not damaged and connected properly.
Disconnect, Inspect, Clean Palm Rest Connection
  • Verify Palm Rest Connectors are clean, not damaged and connected properly.
  • Remove the Palm Rest connector to inspect and assure the Palm Rest connectors are clean and not damaged. See pg 89-90, or as noted in the PDF reader as pg 95-96, of the "thinkpad t40 t40p t41 t41p t42 t42p Maintenance Manual" for more details if needed. This manual is found in the Attached Documents section at the end of this Guide.
  • Insert and reconnect the Palm Rest connector making sure the connection is properly seated.
Insertar traducción aquí
