Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
No hay imagen
Very connections are Clean, Not Damaged and Connected Properly
  • The following steps can be performed in sequential order or one component at a time noting to be very careful when removing and replacing components to assure the connections are clean, not damaged and connected properly.
  • The easiest connections to verify are the Hard Drive, UltraBay Slim Device connections and the Memory Module under the memory cover on the bottom side of the laptop.
  • You can also try this method and see if that is effective
  • - Unplug the AC adapter.
  • - Take out the battery.
  • - Press the power button 10 times in a row at one second intervals.
  • - Press and hold the power button for 30 seconds.
  • - Replace the battery back and push the power button.
Insertar traducción aquí
