Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Paso 2
Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case. This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener,  heat gun, or hair dryer. This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener,  heat gun, or hair dryer.
  • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
  • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
Tira de la ventosa con presión constante y firme e inserta una púa de apertura entre el panel frontal y caja trasera.
Esto requiere una gran cantidad de fuerza y paciencia. Si tienes problemas, mueve la ventosa y pantalla para ablandar el adhesivo o aplicar calor con una pistola de calor, iOpener o secador de pelo.
