Inglés
Español
Paso 31
For protection of the wires, you can use a piece of braided sleeve. On a Full Bear Upgrade, make sure it is tight enough so your X-ends can touch the Z-tops. Prinda cable should go just over top belt.  You can rotate the zip tie head down to help hold it in place. Make sure it not an obstacle when the extruder hits the end stop. Motor wire can go over the top of the carriage. Wire connector alternatively can sit in the top right corner
Wiring - Option 2
  • For protection of the wires, you can use a piece of braided sleeve. On a Full Bear Upgrade, make sure it is tight enough so your X-ends can touch the Z-tops.
  • Prinda cable should go just over top belt. You can rotate the zip tie head down to help hold it in place. Make sure it not an obstacle when the extruder hits the end stop.
  • Motor wire can go over the top of the carriage. Wire connector alternatively can sit in the top right corner
  • Blower fan wire goes over the top of the carriage and is secured with a zip tie
  • Hotend fan wire can go directly over beld. Too much wire here, can cause issues with homing. Check that the X-end can tough the carriage.
Insertar traducción aquí
