Inglés
Español
Paso 29
Insert the belt into the bottom pockets if you are using a stock MK3 X-axis. Make sure the belt is fully inserted and that the belt teeth are matching the profile of the pocktes
Belt
  • Insert the belt into the bottom pockets if you are using a stock MK3 X-axis. Make sure the belt is fully inserted and that the belt teeth are matching the profile of the pocktes
  • Skelestruder supports the Bear X-axis. If you have a MK3 bear upgrade or just use the Bear X-axis on your stock machine, use the top pockets for the right belt path between the X-ends
  • Optional: Insert a 10mm piece of belt in the channel not used on each side, to provide extra clamping.
Insertar traducción aquí
