Inglés
Español
Paso 23
Use 2X M3x12 to screw Fan Shroud on the Noctua's right side. The wire outlet will be located top right when mounting the fan to the assembly. The logo of the fan needs to point to the inside of the E-Cage Make sure the Fan Shroud's screw hole is aligned with the mount on E-Cage S
Noctua Prep
  • Use 2X M3x12 to screw Fan Shroud on the Noctua's right side. The wire outlet will be located top right when mounting the fan to the assembly. The logo of the fan needs to point to the inside of the E-Cage
  • Make sure the Fan Shroud's screw hole is aligned with the mount on E-Cage S
  • Make sure the bottom left screw will catch the mount on E-Cage S. The E-Cage S mount is behind the screw hole shown in the circle. Make sure it is pushed all the way up.
Insertar traducción aquí
