Inglés
Español
Paso 20
Insert motor through hole in Spider and make sure the belt warps around the Pulley (or Pinion).  Recommend wires exit upper left. You can turn the motor connector in a different direction if you prefer a different route for the wire Tighten M3x10 as shown in picture 1
Motor
  • Insert motor through hole in Spider and make sure the belt warps around the Pulley (or Pinion). Recommend wires exit upper left.
  • You can turn the motor connector in a different direction if you prefer a different route for the wire
  • Tighten M3x10 as shown in picture 1
  • Tighten M3x18 as shown in picture 2
  • Tighten M3x18 motor anchor screw with allen key as shown in picture 3
  • Be careful if PINDA already installed. Best to use Allen key with ball end since approach is angled.
  • Unscrew all screws, half a turn after tightening and turn the motor a little bit away from the wheel to tighten the belt
  • Do not over-tighten the screws or the belt. It does not need to be as tight as the other belts on X and Y
Insertar traducción aquí
