Inglés
Español
Paso 19
Screw on spider with M3x12 screw. Remove tenisoner for next step First insert screw head with spring into slot in E-Cage. Make sure spring sits underneath the slot Pull up Tensioner by hand and slip it into the slot prepared in the idler. If it is to hard to insert, do not use excessive force but loosen the tensioner knob a little
Spider + Tensioner
  • Screw on spider with M3x12 screw. Remove tenisoner for next step
  • First insert screw head with spring into slot in E-Cage. Make sure spring sits underneath the slot
  • Pull up Tensioner by hand and slip it into the slot prepared in the idler. If it is to hard to insert, do not use excessive force but loosen the tensioner knob a little
  • Alternatively, wait until the very end to install the tensioner
  • When pulling up the tensioner, it is tempting to press down the extruder assembly to work against the force pulling up. Try to not lean too much on the extruder to assure you are not bending any rods, etc.
Insertar traducción aquí
