Inglés
Español
Paso 18
Get Motor, Tensioner, Spider, Pulley (or Pinion if you printed one) and Pinda Hardware: M3x18 + M3x12 + 2X M3x10
Spider + Motor + Pinda + Tensioner
  • Get Motor, Tensioner, Spider, Pulley (or Pinion if you printed one) and Pinda
  • Hardware: M3x18 + M3x12 + 2X M3x10
  • Put Pulley (or printed Pinion) on the motor shaft as shown on the second picture. Do not worry so much about the position on the shaft, you can adjust that later if necessary
  • If your Pulley has two grub screws, make sure to tighten both. Otherwise one might come loose and cause the Pulley to get jammed with the Spider when in use later
  • You can use the stock MK3 extruder stepper motor if you do not have a slim stepper at hand. But one of the main benefits of Skelestruder is the loss of weight to achieve higher printing speeds. This is limited with the bigger motor. It still will be a great working Extruder though!
Insertar traducción aquí
