Inglés
Español
Paso 16
Insert Shaft into E-Cage, through front bearing.  Add Bondtech with teeth toward rear.  Press shaft through rear bearing until Wheel touches E-Cage Make sure to orientate the Wheel with the screw on the top Bondtech scrub screw and Wheel screw need to be aligned, so Bondtech gear can be secured to the flat part of the shaft. Otherwise it might slip in use later
Wheel + Bondtech
  • Insert Shaft into E-Cage, through front bearing. Add Bondtech with teeth toward rear. Press shaft through rear bearing until Wheel touches E-Cage
  • Make sure to orientate the Wheel with the screw on the top
  • Bondtech scrub screw and Wheel screw need to be aligned, so Bondtech gear can be secured to the flat part of the shaft. Otherwise it might slip in use later
  • Make sure the Bondtech gears are aligned with the filament path. Use a piece of filament to check
Insertar traducción aquí
