Inglés
Español
Paso 14
Get Idler, two nylon washers and one M3x40mm screw. Insert screw through Carriage and E-cage B until tip pokes through.  Hang a nylon washer on the screw tip.  Place Idler as presented and push screw through most of the way.  Slide second washer between Idler and E-cage F and push screw through to nut. Tighten screw finger tight only
Idler
  • Get Idler, two nylon washers and one M3x40mm screw.
  • Insert screw through Carriage and E-cage B until tip pokes through. Hang a nylon washer on the screw tip. Place Idler as presented and push screw through most of the way. Slide second washer between Idler and E-cage F and push screw through to nut.
  • Tighten screw finger tight only
Insertar traducción aquí
