Inglés
Español
Paso 13
Before proceeding, check your progress again and make sure all is aligned. This avoids taking things apart again during the assembly. Insert M3x18 from the back into E-Cage F as motor anchor screw The bearings of E-Cage B and E-Cage F are aligned
E-Cage Check
  • Before proceeding, check your progress again and make sure all is aligned. This avoids taking things apart again during the assembly.
  • Insert M3x18 from the back into E-Cage F as motor anchor screw
  • The bearings of E-Cage B and E-Cage F are aligned
  • V6 is aligned correctly
  • No gaps between E-Cage B and E-Cage F. Inlet is be secured without gaps.
Insertar traducción aquí
