Inglés
Español
Paso 12
Before proceeding, check that V6 is aligned correctly. You wont be able to change this later. Remove E-Cage F and turn heatsink without much force to correct. Do not turn the heatblock, since it might loosen heatbreak and nozzle. You can either align square with cage (as shown) or angled slightly to align with Omega nozzles which are offset.  see Omage close-up Use two M3x25 to screw E-Cage together. Turn both screws equally to avoid bending of any parts
E-Cage F II
  • Before proceeding, check that V6 is aligned correctly. You wont be able to change this later. Remove E-Cage F and turn heatsink without much force to correct. Do not turn the heatblock, since it might loosen heatbreak and nozzle.
  • You can either align square with cage (as shown) or angled slightly to align with Omega nozzles which are offset. see Omage close-up
  • Use two M3x25 to screw E-Cage together. Turn both screws equally to avoid bending of any parts
  • Tip: first time tightening cage, nuts may not be fully set, or burrs on faces, can have trouble catching both screws. Press one side and screw it snug, then release. Do the same to the other side. Then tighten both screws equally.
  • Check that E-Cage has no gaps around Inlet or between halves after tightening
Insertar traducción aquí
