Inglés
Español
Traduciendo paso 1
Paso 1
No hay imagen
Printing Preparation
  • There are many options for filament between type and color. You can mix and match to suit your style and needs.
  • Generally I recommend PETG as it has good all around properties. This is the same as the stock extruder. I used an all PLA version for about 9 months with little trouble however. Annealing is another option, but is challenging due to the shrink factor.
  • Certain parts have unique needs that will favor one type over the other. See part listings.
  • Some parts make look slightly different over time as new versions come out, but functionality and printing are correct as listed.
  • I use and test all parts in Slic3r PE. Print parts as oriented, do not rotate around X or Y. Using default settings unless otherwise indicated below.
  • recommend 0.15 layer, gyroid
Insertar traducción aquí
