Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Switch the headlight on. The ammeter should show discharge. If it shows positive charge, you need to reverse the ammeter connections.
Test it
  • Switch the headlight on. The ammeter should show discharge. If it shows positive charge, you need to reverse the ammeter connections.
  • Switch the headlight off, put the ignition switch to "IGN" and start the engine as usual
  • The ammeter should show positive charge
  • Switch on the headlight. The ammeter should still show positive charge.
  • Check the horn and brake lights. Everything should work as normal.
Insertar traducción aquí
