Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Using an appropriately sized socket and socket wrench, remove the oil drain plug. (In a pinch, you can use an adjustable wrench.) Twist counter-clockwise to loosen it. Let the oil completely drain from the car and into the drain pan.
  • Using an appropriately sized socket and socket wrench, remove the oil drain plug. (In a pinch, you can use an adjustable wrench.) Twist counter-clockwise to loosen it.
  • Let the oil completely drain from the car and into the drain pan.
  • Replace (reinsert) the plug by twisting it clockwise. Tighten it with the wrench following the same clockwise motion.
  • After the plug is replaced, wipe it down with a dirty rag to clean off any outside oil. This ensures that oil will not drip onto the ground.
Insertar traducción aquí
