Saltar al contenido principal
Inglés
Español
Paso 4
Dampen a microfiber cloth with >90% isopropyl alcohol and wipe down the entire surface of the keyboard, paying special attention to the space between keys, and areas that are noticeably grimy. Isopropyl alcohol that is >90% pure is generally free enough of impurities that it won't damage sensitive electronic equipment, but it's still a good idea to be careful with it! The cloth you use to wipe the keyboard during this step should be damp, not dripping wet.
Grease & Grime
  • Dampen a microfiber cloth with >90% isopropyl alcohol and wipe down the entire surface of the keyboard, paying special attention to the space between keys, and areas that are noticeably grimy.
  • Isopropyl alcohol that is >90% pure is generally free enough of impurities that it won't damage sensitive electronic equipment, but it's still a good idea to be careful with it! The cloth you use to wipe the keyboard during this step should be damp, not dripping wet.
Humedece un paño de microfibra con> 90% de alcohol isopropílico y limpie toda la superficie del teclado, prestando especial atención al espacio entre las teclas y las áreas que son notablemente sucias.
El alcohol isopropílico que es> 90% puro es generalmente libre de impurezas que no dañarán equipos electrónicos sensibles, pero es una buena idea tener cuidado con esto. El paño que uses para limpiar el teclado durante este paso debe estar húmedo, no goteando.
