Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
  • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
  • Repeat for the other two grips
  • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
  • The small one on the back is a bit difficult to get started, but not really difficult to remove.
  • The one on the AV panel will be easier if you open up the AV port cover.
  • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
  • Optionally throw the balled up adhesive at people pretending its a booger :)
Insertar traducción aquí
