Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 20 guías que incluyen este paso.
Inglés
Español
Paso 5
In the following steps, you will be loosening and freeing the plastic frame that surrounds the screen. It is connected to the rear case with several clips. Starting at the top right of the device, insert a plastic opening tool into the gap between the plastic frame and the aluminum rear case. Slide the tool down this crack, loosening the frame from the case.
  • In the following steps, you will be loosening and freeing the plastic frame that surrounds the screen. It is connected to the rear case with several clips.
  • Starting at the top right of the device, insert a plastic opening tool into the gap between the plastic frame and the aluminum rear case.
  • Slide the tool down this crack, loosening the frame from the case.
Insertar traducción aquí
