Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Before you begin, it's a good idea to test-fit your new battery in the iPhone. This works best after reinstalling the speaker and Taptic Engine. Refer to the guide you used to remove your old battery.
  • Before you begin, it's a good idea to test-fit your new battery in the iPhone.
  • This works best after reinstalling the speaker and Taptic Engine. Refer to the guide you used to remove your old battery.
  • Make sure the battery connector lines up correctly with its socket on the logic board.
  • Be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
Antes de comenzar, es una buena idea poner a prueba tu batería nueva en el iPhone sin el adhesivo.
Esto funciona mejor luego de reinstalar el altavoz y el Motor Táptico. Sigue la guía que usaste para remover la batería vieja.
Asegúrate de que el conector de la batería se alinee con el zócalo en la placa lógica.
Ten cuidado de no tocar la cámara del Fca ID y el hardware del sensor a lo largo del borde superior del iPhone (el área de la "muesca")
[* black] Before you begin, it's a good idea to test-fit your new battery in the iPhone, without the adhesiveiPhone.
[* icon_note] This works best after reinstalling the speaker and Taptic Engine. Refer to the guide you used to remove your old battery.
[* icon_reminder] Make sure the battery connector lines up correctly with its socket on the logic board.
[* icon_caution] Be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
