Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up). If your battery came with new adhesive strips already installed, skip to Step 7.
  • If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
  • If your battery came with new adhesive strips already installed, skip to Step 7.
  • If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
Si la puesta a prueba salió bien, saca la batería y colócala boca abajo en tu superficie de trabajo (con los contactos del conector hacia arriba)
Si tienes una batería de dos celdas, asegúrate de que las celdas estén alineadas como cuando están instaladas en el iPhone.
[* black] If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
[* icon_reminder] If your battery came with new adhesive strips already installed, '''[guide|117505|skip to Step 7|stepid=228264]'''.
[* black] If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
