Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Take a plastic pry to to pry out the battery from its casing. The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok . Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
  • Take a plastic pry to to pry out the battery from its casing.
  • The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok .
  • Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
Insertar traducción aquí
