Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid. Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case. Use a plastic pry tool to remove the battery connector from the logic board.
  • Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid.
  • Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case.
  • Use a plastic pry tool to remove the battery connector from the logic board.
Insertar traducción aquí
