Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass. When pulling the screen off the chassis be careful not to cut  the ribbon cable the connect the screen to the logic board. Take your time to pry open the screen from the chassis. In this process you can easily break the screen or crack it.
  • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
  • When pulling the screen off the chassis be careful not to cut the ribbon cable the connect the screen to the logic board.
  • Take your time to pry open the screen from the chassis. In this process you can easily break the screen or crack it.
Insertar traducción aquí
