Saltar al contenido principal
Inglés
Español
Paso 4
In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease. If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips. To increase your odds of success:
  • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease.
  • If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips.
  • To increase your odds of success:
  • Don't press down on the battery. Hold the iPhone firmly by its sides.
  • Keep the strips flat and unwrinkled as you pull.
  • Pull very slowly, giving the strip time to stretch and separate. It takes around 15-30 seconds of stretching to remove each strip.
  • Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
  • If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
En los siguientes pasos, jalarás de cada lengüeta para estirar despacio el adhesivo por debajo de la batería. Este adhesivo especial de estiramiento-liberación pierde su fijación cuando se estira y luego sale en tu mano, permitiéndote levantar la batería con facilidad.
Si las tiras se rompen, no entres en pánico. No siempre funcionan como deben. Sigue leyendo algunos de los pasos adicionales para remover tiras rotas.
Para aumentar tus posibilidades de éxito:
No presiones la batería. Sujeta el iPhone firmemente de sus laterales.
Mantén las tiras planas y sin arrugas mientras jalas.
Jala muy lentamente, dándole a la tira tiempo para estirarse y separarse. Lleva 15-30 segundos de estiramiento para remover cada tira.
Jala a un ángulo bajo para que la tira no se enganche a lo largo del borde inferior de la batería.
Si la tira se rompe por debajo de la batería y no la puedes recuperar, sigue con las otras tiras y luego continúa con los pasos adicionales abajo.
