Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 2
Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini. During reassembly, notice that the silver clip hugs either side of the lower beveled edge of the AC connector. When sliding the clip back in it will hit a stop, but not click into place. You will know that you did it correctly because it will not easily move out of position. During reassembly, notice that the silver clip hugs either side of the lower beveled edge of the AC connector. When sliding the clip back in it will hit a stop, but not click into place. You will know that you did it correctly because it will not easily move out of position.
  • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
  • During reassembly, notice that the silver clip hugs either side of the lower beveled edge of the AC connector. When sliding the clip back in it will hit a stop, but not click into place. You will know that you did it correctly because it will not easily move out of position.
Tira del retenedor de metal plateado del AC-In hacia el lado de la carcasa exterior y remuevelo del mini.
Durante el re-ensamblaje, observa que el clip plateado abraza a ambos lados del borde biselado inferior del conector de CA. Al deslizar el clip hacia adentro, se detendrá, pero no encajará en su lugar. Sabrás que lo hiciste correctamente porque no se moverá fácilmente de su posición.
