Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 33 guías que incluyan este paso.
Traduciendo paso 3
Paso 3
Lift the fan out of the mini for enough clearance to access its connector.
Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
Remove the fan.
[* black] Lift the fan out of the mini for enough clearance to access its connector. |
[* black] Grab all the wires at once and gently pull '''straight up''' to disconnect the fan from the logic board. [* icon_caution] Do '''not''' pry at the socket, or you |
[* black] Remove the fan. |
