Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 6
PROCEED WITH CAUTION!!! The antenna cable and the battery contacts are soldered onto the board.
  • PROCEED WITH CAUTION!!! The antenna cable and the battery contacts are soldered onto the board.
  • Your monitor should look like this, with a small gap between the main board and the rear casing.
  • The next step will merely free the volume control dial from the casing and NOT free the main board from the casing.
  • To remove the main board from the casing, you MUST desolder the antenna cable and two battery contacts from the board.
Insertar traducción aquí
