Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
The brackets are lightly adhered in place. Gently lift to unstick and remove each bracket, being careful not to bend it. If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
  • The brackets are lightly adhered in place.
  • Gently lift to unstick and remove each bracket, being careful not to bend it.
  • If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
Los soportes se adhieren ligeramente en su lugar.
Suavemente levanta para despegar y remover cada soporte, teniendo cuidado de no doblarlos.
Si es necesario, aplica un poco de calor con un pistola de calor para ablandar el adhesivo (No es recomendable colocar un iOpener en los soportes ya que podría doblar los contactos de muelle a lo largo de la parte superior)
