Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 10
In the next two steps, you will install the hard drive into its bracket. When inserting the hard drive, be sure to place it in its bracket cable side up with the SATA connector closest to the bulge in the bracket seen in the third picture. Push the set screws into the grommets in the bracket and install the hard drive up into its bracket as seen in the second picture.
  • In the next two steps, you will install the hard drive into its bracket.
  • When inserting the hard drive, be sure to place it in its bracket cable side up with the SATA connector closest to the bulge in the bracket seen in the third picture.
  • Push the set screws into the grommets in the bracket and install the hard drive up into its bracket as seen in the second picture.
Insertar traducción aquí
