Inglés
Español
Paso 2
Find and detach all connections to  motherboard.   There are connections at the battery, at the camera, ground wire, plastic connections are charging port, and SDRAM DDR3 512MB. Remove these connections from the motherboard, but leave the components in place.
  • Find and detach all connections to motherboard. There are connections at the battery, at the camera, ground wire, plastic connections are charging port, and SDRAM DDR3 512MB. Remove these connections from the motherboard, but leave the components in place.
  • Remove using soldering iron and solder vacuum to break current welds.
Insertar traducción aquí
