Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 6
Unscrew the two PH000 screws holding the joystick down. Make sure to NOT disconnect the two side board cables. It may cause fatal damage to the controller.
Removing the joystick
  • Unscrew the two PH000 screws holding the joystick down.
  • Make sure to NOT disconnect the two side board cables. It may cause fatal damage to the controller.
  • Before you remove the joystick, remove the secured ribbon cable by opening the clip using the tip of a spudger.
  • Note that there is a small gasket below the joystick and that it has to be re-seated in place before inserting the new joystick.
Insertar traducción aquí
