Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
The jack will be holding up the car so that the car does not fall on you. Make sure that the vehicle is secure on the jack.  Check that your vehicle is in park and has the emergency brake/parking brake on.
  • The jack will be holding up the car so that the car does not fall on you. Make sure that the vehicle is secure on the jack. Check that your vehicle is in park and has the emergency brake/parking brake on.
  • Place the jack in the proper location on the axle between either the front or rear tires, depending on which tire is flat.
  • Refer to your Jeep manual to determine the proper location for the jack under your vehicle.
  • In this case, the rear driver's side tire was the "flat tire" so the jack will be placed on the axle between the rear tires on the driver's side of the Jeep.
Insertar traducción aquí
