Inglés
Español
Paso 3
To protect the internal cables and components, you will need to carefully disconnect  the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver. Remove the metal plate with tweezers.
  • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
  • Remove the metal plate with tweezers.
  • Disconnect the battery connector from the motherboard using the spudger.
Insertar traducción aquí
