Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
Lay the iOpener clear-side down, flat on the edge of the device, over an adhesive seal you wish to heat. The liquid will flatten the iOpener against the surface, ensuring good heat conduction. Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel. At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
  • Lay the iOpener clear-side down, flat on the edge of the device, over an adhesive seal you wish to heat. The liquid will flatten the iOpener against the surface, ensuring good heat conduction.
  • Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel.
  • At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
  • During the procedure you may need to reheat the iOpener. To prevent overheating the iOpener, always wait until the iOpener has cooled enough to touch safely. Do not microwave the iOpener for more than thirty seconds at a time.
Coloca el iOpener con el lado claro hacia abajo, plano en el borde del dispositivo, sobre un sello adhesivo que desees calentar. El líquido aplanará el iOpener contra la superficie, asegurando una buena conducción del calor.
Deja la bolsa en el dispositivo durante aproximadamente 90 segundos antes de intentar abrir el panel frontal.
En este punto, deberías poder comenzar a hacer palanca debajo de la pantalla con una herramienta de apertura de plástico. Asegúrate de ver la guía específica de tu dispositivo para saber dónde y cómo hacerlo.
A lo largo del procedimiento, puede que necesites recalentar iOpener. Para evitar el sobrecalentamiento del iOpener, siempre espera hasta que el iOpener se haya enfriado lo suficiente como para tocarlo sin quemarte. No calientes el iOpener en el microondas durante más de treinta segundos seguidos.
