Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Remove the J0mm Phillips #0 screw which is shown in image one. This screw keeps the metal bar from sliding out. The laser lens is attached to this metal bar on one side and on the other side is the sliding motor. Slide out the rod from its placement. This will detach the laser lens and the ribbon cable from the tray. Slide out the rod from its placement. This will detach the laser lens and the ribbon cable from the tray.
  • Remove the J0mm Phillips #0 screw which is shown in image one. This screw keeps the metal bar from sliding out. The laser lens is attached to this metal bar on one side and on the other side is the sliding motor.
  • Slide out the rod from its placement. This will detach the laser lens and the ribbon cable from the tray.
Insertar traducción aquí
