Saltar al contenido principal
Inglés
Español
Paso 2
The replacement adhesive should only be applied to the edges of the frame, but may come with the center filled in. To remove the unnecessary center section of the adhesive strip, carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout. To remove the unnecessary center section of the adhesive strip, carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout.
  • The replacement adhesive should only be applied to the edges of the frame, but may come with the center filled in.
  • To remove the unnecessary center section of the adhesive strip, carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout.
Insertar traducción aquí
