Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver. After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
  • After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
Insertar traducción aquí
