Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
Repeat the same process as in Step 6 to  release the flat ribbon cable from the black rectangular latch Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on. Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
  • Repeat the same process as in Step 6 to release the flat ribbon cable from the black rectangular latch
  • Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on.
  • Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
  • Be sure that the transparent case or the black motherboard are being held or resting on a surface so that neither falls when the clip is released.
Insertar traducción aquí
