Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Unscrew the four 4.0 mm Phillips #00  screws on either side of the transparent case. Separate  the transparent half of the case from the white half. Only separate  the  two halves enough for them to be apart. The flat ribbon cable  is short and its connection is delicate.
  • Unscrew the four 4.0 mm Phillips #00 screws on either side of the transparent case.
  • Separate the transparent half of the case from the white half.
  • Only separate the two halves enough for them to be apart. The flat ribbon cable is short and its connection is delicate.
Insertar traducción aquí
