Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 10
The display carries a status LED, some interconnect boards and chips that are fairly easily pried off of their adhesive. The screen itself appears to be a single fused unit, so glass and display will need replacing together, making for a more expensive part. You will also have to be extra careful not to separate the layers when trying to access any of the components in the display assembly. Pictured is a cracked display, and damage from separating the layers.
  • The display carries a status LED, some interconnect boards and chips that are fairly easily pried off of their adhesive.
  • The screen itself appears to be a single fused unit, so glass and display will need replacing together, making for a more expensive part.
  • You will also have to be extra careful not to separate the layers when trying to access any of the components in the display assembly. Pictured is a cracked display, and damage from separating the layers.
  • The components on the rear case include: upper sensor board (on a very fragile board), several antennas secured by a lot of tape (copper and otherwise), and hinges (with rubber plugs to hold cables).
  • Ideally the antennas won't fail, but their cables run through the hinges, which means some stress over time. The copper tape will complicate replacement.
Insertar traducción aquí
