Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
In attempting to remove the display, we removed the display cables (with pull tabs that didn't work very well) and the antenna interconnect cables (covered with an adhered plastic plate complicating repair). The display assembly looks removable, but the final screw in the hinge is trapped under the motherboard. While a laptop is less likely to need a screen replacement compared to smaller mobile devices, it's still an important part to access. This layering makes screen replacement unnecessarily tough.
  • In attempting to remove the display, we removed the display cables (with pull tabs that didn't work very well) and the antenna interconnect cables (covered with an adhered plastic plate complicating repair).
  • The display assembly looks removable, but the final screw in the hinge is trapped under the motherboard.
  • While a laptop is less likely to need a screen replacement compared to smaller mobile devices, it's still an important part to access. This layering makes screen replacement unnecessarily tough.
  • The speakers look removable but their wires are trapped under the trackpad for no discernible reason.
  • Removable after the battery: the trackpad assembly and fingerprint reader, after its bracket is removed.
Insertar traducción aquí
