Saltar al contenido principal
Inglés
Español
Paso 5
You should find two connected black cylinders in the top left and right-hand corners of the device containing the two silver stoppers for the drawer. Unscrew the 1.2mm Phillips #1 screws connected to the black cylinders by using the Phillips +1 driver, rotate it counterclockwise and remove it. There should be one screw connected to each of the black cylinders.
  • You should find two connected black cylinders in the top left and right-hand corners of the device containing the two silver stoppers for the drawer.
  • Unscrew the 1.2mm Phillips #1 screws connected to the black cylinders by using the Phillips +1 driver, rotate it counterclockwise and remove it.
  • There should be one screw connected to each of the black cylinders.
Insertar traducción aquí
