Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 4
Repeat the above steps to remove the remaining three adhesive strips. Be sure to hold onto the battery as you remove the final strip, or it may fling out of the iPhone unexpectedly.
  • Repeat the above steps to remove the remaining three adhesive strips.
  • Be sure to hold onto the battery as you remove the final strip, or it may fling out of the iPhone unexpectedly.
  • If you removed all of the adhesive strips successfully, skip the next step.
  • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
  • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • Be careful not to damage the ribbon cables or the wireless charging coil directly underneath the battery.
  • For an alternative method to unstick the battery, continue with the next step below.
Repite el paso previo para remover las tres tiras adhesivas restante.
Asegúrate de sostener al batería mientras remueves la tira final o puede salir disparada del iPhone de manera inesperada.
Si remueves todas las tiras adhesivas exitosamente, omite el próximo paso.
Si el adhesivo se rompe debajo de la batería y no puede ser recuperado, aplica un poco de alcohol isopropilico de alta concentración (mayor a 90%) debajo el borde de la batería en el area del adhesivo roto.
Espera por alrededor de un minuto para que el alcohol debilite el adhesivo. Usa el lado plano de una spudger para levantar gentilmente la batería.
No trates de levantar la batería forzosamente. Si es necesario, aplica unas gotas mas de alcohol par debilitar mas el adhesivo. Nunca deformes o perfores la batería con tu herramienta.
Se cuidadoso de no dañar los cables o la bobina de carga inalámbrica directamente debajo de la batería.
Para métodos alternativos en como despegar la batería, continua con el siguiente paso debajo
